Hello
I need to set and read temperature to/from Watlow '96 using LabVIEW. From this discussion forums I found library files called Watlow96.llb written and posted by Brian Vibert (Thanks Brian). I tried to run it using RS232-RS485 converter. However, I got the following error: Serial port timeout; bytes not received at serial port.
My settings are Baud rate: 9600, timeout: 10sec, data bits: 8, parity: None and flow control: none.
Can any one help me sorting out this matter.
Thank you for your help.
Nur
