I was under same doubt when this new layout came and it was always showing that all time kudos.
-The workaround what i did is make the Top Kudoed Authors component: Time range in My settings->preferences->Kudos tab.
-There is limit to this, after rank 6 it doesn't show the count. Since, you are in Top 6 you should be able to see the count. And refresh the board page and not the kudos leader page. The same works for month also but not after you click to exapand the tab.
Thank you for reporting this issue, this particular case is a known bug and it has been escalated to Lithium for further assistance. We will post updates when available.
Please let me know if any further issues or concerns.
