Feedback on NI Community
Reply
Finding unread discussions
when I choose a specific forum, say Instrument Control or LabWindows/CVI, how can I find the threads I haven't read?
The very recent unread threads are listed in a box displayed on the upper right of my screen - but this works only for recent threads - how can I find older unread threads?
On http://forums.ni.com/ below the 'Top Kudoed Authors' there is a list of 'Unread Discussions', but this list refers to all NI forums - while I am interested only in unread discussions of a specific forum.
Also, using search or advanced search I found no way to achieve this goal.
Thanks...
Wolfgang
Message 1 of 11
(4,321 Views)
Re: Finding unread discussions
Hi Wolfgang,
The following links will take you to the unread discussions of the two boards you cited in your post:
In order to generate the URL's to all unread posts of a specific board, you will need to use the following generic URL, and simply replace the bID# with the ID number of the board you want to view:
http://forums.ni.com/t5/forums/unreadpostspage/board-id/bID#/post-type/thread
You can find the bID# value by navigating to your board of interest from the main landing page and then grabbing the value from the URL right after bd-p/.
For example,
Also, on a simpler note, if you just navigate to the board itself, there should be an Unread Discussions widget on the right that will take you to unread posts in that board.
Hope this helps!
Stephanie R.
Message 2 of 11
(4,298 Views)
thanks for your reply. However, the two links you have provided do not resolve my question: clicking on the 'Unread CVI Threads' link displays zero unread discussions - I assume simply because there are no recent unread discussions. But there are about 20000 new (= unread) posts, at least according to the overview given here: http://forums.ni.com/
I'd like to be able to move to the most recent new/unread post, even if it is a year old...
Wolfgang
Message 3 of 11
(4,286 Views)
Hope this helps!
Hm, it doesn't work for me...
Here is the main forum view which correctly claims that there are about 20000 unread discussions in the CVI forum:
Now, what I would expect is something like this, showing the GPIB forum:
However, navigating to the CVI forum, there is no such 'Unread Discussion' widget, because (I suppose) the unread discussions are not recent unread discussions but older unread discussions....
So let me reiterate my question: How can I find older unread threads?
Thanks.....
Message 4 of 11
(4,217 Views)
Hi Wolfgang,
I do see the behavior you referenced on my end, as well.  I have submitted a request to the vendor because I believe you are right -- this is not expected behavior.  I'll keep you updated by posting back to this thread when I hear back.
Thank you again for your notification on this matter -- and I apologize for the inconvenience!
Stephanie R.
Message 5 of 11
(4,206 Views)
No need to apologize Smiley Wink Instead many thanks for taking care!
Message 6 of 11
(4,199 Views)
Hi Wolfgang,
We have heard back from Lithium about this matter.  They were looking into it for quite some time because apparently NI hasn't been the only community that saw such strange behavior with the unread messages feature.  Apparently this has been confirmed as a bug, and has been escalated to the developers so they can research a fix.  As of now, they do not have a release date for the patch.
Thank you again for your feedback!
Stephanie R.
Message 7 of 11
(4,112 Views)
Thanks for the update!
Message 8 of 11
(4,103 Views)
Highlighted
it appears that this functionality is still broken... Smiley Sad
srdfrn wrote:
Hi Wolfgang,
Message 9 of 11
(3,982 Views)
Is there room for hope to have this bug fixed? It's going to celebrate its anniversary Smiley Frustrated
Message 10 of 11
(3,860 Views)
