Feedback on NI Community
'Error -10401 Occurred at AI Clock Config' When Running Certain Examples ...
I tried following the suggestion given earlier on the website link http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/50f8faa83c79f07f862569f90041855b?OpenDocument
So I changed the Channel A to 0 and Channel B to 1, but still get the same error. I am doing a VI on my own that is getting the same error so I am very confused.
(4,939 Views)
Try posting this to the LabVIEW general forum:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=8&RFORMNUMBER=2&RHIDETAG=TRUE&UCATEGORY_0=_49&UCATEGORY_S=0
the DSA forum:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=8&RFORMNUMBER=2&RHIDETAG=TRUE&UCATEGORY_0=_36&UCATEGORY_S=0
or contact NI directly at:
http://sine.ni.com/apps/we/niae_asc.main
(4,939 Views)
Hello;
I don't have detail on what exactly you are trying to accomplish there.
Can you give me more details such as what board you are using, what you need to accomplish, etc?
Meanwhile, the error -10401 occurs if you are trying to address a device that is not present. If MAX cannot see the DAQ card or you have changed the device number of the card, you will get this error. So, I recommend you first use MAX to do basic testing with the board, and check if the device number you are setting at the LV VI corresponds to the device number MAX assigned to that board.
Hope this helps.
Filipe
(4,939 Views)
Hi, I was just running one of the given demos in the example directory listed above. I was trying to run the same demo that someone else ran and was getting the -10401 error. So I read up on the error on this website and found that it was needed to change channel A to 0 and channel B to 1. I did this, but still received the same error. I am implementing the same VI in my code and am receiving this error. I don't have any board attached directly, just doing a software implementation of a DAQ.
THanks
(4,939 Views)
