11-25-2016 05:32 PM
@LiliMcDonald wrote:X. - I edited my post above to clarify on some of the points you raised.
As for the Community Hub, that particular group existed as a way to provide help documents or to ask questions on using the NI User Group Community. As the NI User Group Community no longer exists, the content within no longer needs to be publicly accessible.
Reading the title of the incriminated bookmarks, I now understand what you mean: these were typically posts about how the previous site worked (or didn't). A bit like the "Feedback on NI Community" forum this thread belongs to.
11-25-2016 06:43 PM
Hi RobertoBozzolo,
I believe Lili provided you a copy of the document via private message. Thanks!
11-26-2016 06:59 PM
https://decibel.ni.com/content/docs/DOC-48417 is another document of mine which has gone AWOL (from this post).
11-26-2016 07:46 PM
An example of dead links on NI's website: How Do I Access the Attribute Nodes of the Individual Elements of a Cluster?
The two links at the bottom of the page are dead.
I have used the form at the bottom of the page to inform NI of this, but this is a black box with no kind of acknowledgment that this did anything or will be followed with any sort of action.
It is clearly old, and now saved in the Wayback Engine.
11-27-2016 01:37 PM
If I create a new test document can you delete it after? Getting everything formatted took a fair bit of time and I don't want to redo it repeatedly.
11-28-2016 03:15 AM
Tilee ha scritto:Hi RobertoBozzolo,
Correct! Thank you all
11-28-2016 11:05 AM
Is there an official channel to recover vanished documents?
11-28-2016 11:31 AM
Hi KitKate,
Do you mind explaining what you mean? Are you looking to use the test document as a template for formatting? We can delete documents if you'll notify one of us (the Community admins) when you need it done.
11-29-2016 01:29 PM
I found 2 published personal documents for you which I will send you via private message.
As these aren't community hosted documents, it is best to use the feedback form or contact form found on the page.
11-29-2016 02:08 PM
I am now able to submit documents for review. Not sure why it didn't work previously.
