Feedback on NI Community
Comments/Questions on New Layout
to add a suggestion to my previous post:
When writing a message the text editor window is narrower then the "white space area" of the website because of the "Message Tags" input field on the right side. When you move that input between "Subject" and "Body" you can make the editor window wider as well as the message tags input:
Message 71 of 174
(1,552 Views)
How do I ask a question!?!?!
It was awkward enough in the old layout but now I cant seem to find any option for adding a question.
Labview 14.0, Labview 12.0
CLAD
Mechanical Engineering Student
Message 72 of 174
(1,529 Views)
one more "bug" (or is it a feature? :D):
When your message is selected as "solution" you get an email notification. That's nice.
But that email shows as topic line "Your answer on Community Home has been accepted as a solution!"
"Community Home" is very generic - using the thread title (or atleast "LabVIEW forum") would be much more descriptive…
Message 73 of 174
(1,517 Views)
HI Gerd,
You were commenting on editor font sizes.  I noticed your messages come up with a lot smaller font than everyone else's.  Even when I set my screen to 100% and everyone's is too big, your's is still a bit smaller than what I considered normal and remember from the old forum layout.  Did you change your editor settings to something specific?
Message 74 of 174
(1,502 Views)
To everyone commenting on font sizes -- we are working on this. Please be patient.
Stephen1995 wrote: How do I ask a question!?!?!
Stephen - where are you seeing this problem? If you go to the LabVIEW board, there is a button that says Start a Topic which will allow you to post a new topic with your question.
GerdW wrote: "Community Home" is very generic - using the thread title (or atleast "LabVIEW forum") would be much more descriptive…
We're aware of this issue and will update it accordingly. It had previously said "NI Discussion Forums."
Message 75 of 174
(1,489 Views)
Hi RavensFan,
nothing special, I just set the text to "font size 2" when posting a message! 😄
(My way to enforce more compact messages in the forum. I did the same with my signature…)
Message 76 of 174
(1,515 Views)
Ahh I see now. I was just clicking the community and then forum option and being presented with forums but no option to start. This is before clicking the boards which I didn't fully understand. Seems simple enough though now
CLAD
Message 77 of 174
(1,508 Views)
Hi Lili,
Message 78 of 174
(1,503 Views)
Gerd -- the text editor wouldn't have changed. This component is a third party component called TinyMCE Editor. In programs such as Microsoft Word, the process works as you described, but I don't recall that being the case here (I have faced my own frustrations with this).  Does anyone else recall how this functioned in the past?
Message 79 of 174
(1,500 Views)
Hi Lili,
one more "complaint" about the editor:
I know (means "I'm sure") I could have text in one line with an embedded image.
Now I tried the same (putting a comment just right to an image): I set the cursor to the right of the image and start to type. Immediately with the first char the cursor jumps to the next line, not allowing to put text right behind an image.
Additionally: when the cursor is below an image and you try to move it left (using cursor keys) the cursor stays below the image. When the cursor is in the text line above an image and you move the cursor to the right it will jump over the image (more or less as expected). Why does it behave different with cursor-left and cursor-right?
The editor behaved different last week and I don't like those subtle changes…
Message 80 of 174
(1,491 Views)
