Feedback on NI Community
Reply
Can we have a button to remove formatting?
[ Edited ]
One of my most-loved features of the gmail editor is the "remove formatting" button.
Sometimes we paste content from elsewhere and the font is just slighty different (arial vs. helvetica vs. tahoma, size, shade of grey) or there are bold or italic embedded codes, for example. Wouldn't it be nice to select that part of the text and just remove all formatting, reverting everything to the default we get when we just start typing plain text into a new editor window?
Currenty, extra formatting is difficult to revert and we either need to go to the html editor or we need to guess what the default font|size|color actually is.
What is the default font? size? color?
Message 1 of 8 (544 Views)
Rif.: Can we have a button to remove formatting?
I second this request which could be a useful addition.
And I second altenbach last question too: every time I tried formatting text to get the aspect of the default editor font and size I ended up with something slightly different from it.
Message 2 of 8 (493 Views)
Hi guys,
It looks like it may be possible for us to enable a "clear formatting" button. We are looking into it and will keep you updated here.
While we work on that, a quick/easy way to clear the formatting from text is to copy/paste it into and back out of a program like notepad, which will strip out the formatting.
We'll keep you updated on this.
Matt
Matt
NI Community Team
Message 3 of 8 (474 Views)
The clear formatting button is now available.
Thanks for the suggestion!
Message 4 of 8 (407 Views)
[ Edited ]
Hi Lili,
I just copied some text from LabVIEW help to the editor window, see this message with the linked Help article.
Then I wanted to remove formatting of the copied text: that didn't work (as expected)!
Neither the table formatting of "current length is…" was removed nor the <headline> tags of the "Data Queue PtByPt Details"…
I had to remove all those HTML tags in the HTML view of the message editor!
CLAD, using 2009SP1 + LV2011SP1 + LV2014SP1 (+ LV2016 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
Message 5 of 8 (341 Views)
Reply
Hi Gerd,
Thanks for reporting this. We were able to reproduce this issue and will escalate this to Lithium for further investigation.
Lili
Message 6 of 8 (316 Views)
Reply
[ Edited ]
Hi Lili,
same issue: the "remove formatting" button wasn't able to remove <h5> and <font> tags…
(After I copied the message topic into the editor window I got this line: <h5>Can we use RS422 serial port communicat<wbr />ion</h5>)
Message 7 of 8 (214 Views)
Reply
Hi Gerd,
The text editor in the community utilizes TinyMCE editor. Unfortunately, the issues you've reported with the "remove formatting" button is functioning like this within TinyMCE itself.
Our recommendation is when pasting formatted text, use Ctrl+Shift+V to paste as plain text. You could also paste it into the HTML tab of the text editor which would strip away any formatting.
Lili
Message 8 of 8 (197 Views)
Reply
