Feedback on NI Community
After specifying a DSN, and an sql statement to SELECT data I can run the Complete SQL
Session VI in the SQL toolkit. The query results return the requested data, and no errors are produced. When I depress the run arrow a second time, I get an illegal operation message and have to shut down Labview. Have you had problems like this before?
(4,885 Views)
Session VI in the SQL toolkit. The query results return the requested data, and no errors are produced. When I depress the run arrow a second time, I get an illegal operation message and have to shut down Labview. Have you had problems like this before?Hello,
You may want to see if there is an update for the ODBC driver of the database you are using. Many times, a crash is caused because of a problem with the driver. You may also want to search the NI website for more information (search for +SQL +Sybase for example, if you are using a Sybase database.)
Good luck!
Sincerely,
Darren Nattinger
(4,885 Views)
