02-17-2012 08:08 AM
I am new to Fieldbus and could use some help getting started. I am having trouble seeing my device in the NI Configurator software. I have Communications manager running and it looks like I can see my NI USB-8486 adapter but I cannot see the device on the other side of the adapter.
I have attached a Word doc with some screen shots.
Thanks for any help you can give.
02-17-2012 09:43 AM
Please get a termination and try again.
It seems that the device isn't powered on correctly.
Thanks.
Chris
02-17-2012 10:15 AM
Thanks for your reply. I will try that and post results.
02-17-2012 12:25 PM
You were correct, thank you. Once I added the Relcom FCS-PH-CC Terminator/Power Supply it worked.
Screen shot attached...
02-17-2012 12:45 PM
yeah, good to hear that.
