FOUNDATION Fieldbus
USB FF Interrface does not show up as a monitor choice
I set up my USB FF interface with tthe NI-FBUS Interface Configuration Utility to monitor the bus. When I start the NI-FBUS Monitor program the only Bus Name that shows in the settings mennu is Simulator. This interface works great with my Configuration Manager. I am using the evaluation version. What am I missing?
(7,725 Views)
Hi LJGremillion,
What's the driver version of your NI-FBUS? The lasted is 15.0. You can update the version if yours is not 15.0.
And you should confirm if you run the NI-FBUS Communications Manager firstly.
Thanks!
(7,719 Views)
My USB-8486 Properties shows:
Driver Provider: Natiional Instruments
Driver Date:       6/9/2010
Driver Version:  4.0.1.49152
I'm not sure where version 15.0 is because when I do a Windows Update Driver, I get the response this is the correct driver for this device.
This is on a Windows 7 32 bit device.
Also, I make sure the Communications Manager is NOT running when I try and run Monitor. Still no interface shows up.
(7,707 Views)
I suggest you run the NI-FBUS Communications Manager firstly. And watching if there is have any error of FF system.
I show you some screenshot to ensure your operation is correct.
Double-click the Port0 of "NI-FBUS Interface Configuration Utility", you can see the Interface Name and Device Tag. According to screenshot " Interface Configuration Utility".
Then enter F9 in NI-FBUS Monitor, you should choose the Bus Name. According to screenshot "Monitor"
Thanks!
(7,680 Views)
