01-03-2015 10:06 AM
NI Monitor does not update. I recently began using Monitor and after activating it with the automatic license utility I set the interface configuration utility to Bus Monitor. NIFBUS configuration works fine. When I go to Bus Monitor and set it to capture, the card is correct, but nothing shows up, not even the live list. I seem to be experiencing similar update issues with both Trend Monitor and Alarm Monitor in that I can get nothing to update in them even after loading and connecting the MIB funcion block and setting the FBs in the devices I want to trend and alarm.
01-04-2015 12:38 AM
01-04-2015 01:54 AM
The email directed me to this reply, which said to check the email. Is there another email I should expect which actually deals with the issue?
