03-28-2014 12:24 AM
I've attached a photo of my powerhub. Connected are H1 devices, one of them being USB-8486.
04-01-2014 01:02 PM
look at these pictures i showed you how i plugged my power hub device and then i run the program and it showed me an error in activation code i think it was another kind of problem but when i am asking for a new code i received a message with this:
Dear Customer,
We apologize for any inconvenience; however, the submitted serial number does not require activation. This product can be used without an activation code.
Please see below links for more information:
http://www.ni.com/license/product_activation.htm
http://www.ni.com/activate
http://www.ni.com/license/activation_faq.htm
National Instruments Services Programs
----- Forwarded by National Instruments - Customer Services [TMD] -----
Heleodoro Cordova Jauregui <heleodoro.cordova@coimsur.com.mx> |
To: |
<activate@ni.com> |
Cc: |
Date: |
2014-03-31 10:28:27.0 |
Subject: |
RV: Enviando por correo electrónico: NIProductsLicenseForm |
so i will show you all the files i have until today.
04-01-2014 01:06 PM
these are other files
04-01-2014 01:09 PM
these are other files the second part or maybe the third
04-01-2014 09:56 PM
Hi JAUREGUI_HELIO,
With the photos, I can only assume you've connected USB-8486 to the powerhub (KLD2-pc-1.1) correctly, if the black wire connected to the 123 456 side on the lower port is USB-8486. If so, there should be no problem.
The reason you've got the email response saying you do not need activation is most likely because you've only purchased the USB-8486 hardware. It could be intended so because NI-FBUS Communication Manager is free for use, using which you can develop application using the API provided (C, VB, .NET, and VI), thus you do not need to activation NI-FBUS Configurator or Monitor which are paid software.
You can give me your serial number for me to check whether your have purchased NI-FBUS Configurator and/or Monitor in your order's configuration.
04-02-2014 10:22 AM
ok the Serial Number: 15AFF72 i would like that you help me.
04-02-2014 09:28 PM
15AFF72 (with software SN H21J14996 on the CD) is NI-FBUS Communication Manager only, and doesn't include NI-FBUS Configurator or Monitor. Please check with your purchasing department.
If you need to configure FF network online, you'll have to use NI-FBUS Configurator.
The product page is here.
