Darren,
Address 0xfa is obviously wrong.
Address range
(decimal)
Address range
(hexadecimal)
Allocation |
0 through 15 |
00 through 0F |
Reserved |
16 through 247 |
10 through F7 |
Permanent devices |
248 through 251 |
F8 through FB |
New or decommissioned devices |
252 through 255 |
FC through FF |
Temporary (“visitor”) devices |
0xF8~FB is also called default address. According to FF spec,
Default Addresses
Default addresses are non-visitor node addresses reserved for DLEs waiting for node address assignment. They are used by field devices
that are in the uninitialized or initialized state and thus have not been assigned an address by the master configuration device. The default
address range is defined and reserved by the Data Link Layer Specification.
You only need to set the address of the device to a unique permanent device address (16~247), I believe, before it can work. You probably don't need to set them to factory defaults.
NI-FBUS VI API can do set address/tag. Configurator can do as well. If you don't have either of these two, I'm afraid you would have to find some other way.
