In the new LabVIEW for LEGO MINDSTORM (LVLM) the templates are in a new location.
Note: To access the tempaltes you must install LVLM and the FTC Toolkit, for more information check the LabVIEW Software Setup for FIRST Tech Challenge 2011-2012.
Step 1. Open LabVIEW for LEGO MINDSTORMS
Step 2. Click Create Program to start a new robot project.
Figure 1. The LabVIEW for LEGO MINDSTORMS Getting Started Window
Step 3. Select Robot Project and FTC Arm & Gripper and click Create, then name your robot and click OK.
Figure 2. The LabVIEW for LEGO MINDSTORMS new program dialog.
Autonomous Tempalte
Once you create a robot using this template you can access the blank autonomous template called "autonomous mode" Double-click this file to open it.
Figure 3.The LabVIEW for LEGO MINDSTORMS Robot Project Center
Teleop Template
LabVIEW for LEGO MINDSTORMS has new tools that allow you to automattically generate a customized teleop template using the Remote Control Editor.
Step 4. Open the Remote Control Editor from the Robot Project Center.
Step 5. Customize you drive mode, drive motors and add any custom buttons.
Step 6. Click Generate Code and LabVIEW for LEGO MINDSTORMS will create a new VI with all of your setting built into the Teleop Template
Figure 4. The LabVIEW for LEGO MINDSTORMS Remote Control Editor with FTC Toolkit features.
