FIRST Tech Challenge Discussions
Reply
Servos not working
Highlighted
Servos not working
in the schematic editor, the two servos we have connected work perfectly fine. In the remote control editor, for one the buttons, we chose the action "move to position", selected one of the servos, and set a certain position for it, then generated the code for it. If we run the prototype from the remote control editor, the servos respond perfectly good according to the position set and everything. However, when we run the teleop (without making any changes to the code generated)  the NXT automatically exits the program and displays "file error".
We have tested out other programs that dont include the code for the servo, and work perfectly fine. The error comes up just when the servos are added into the teleop code. Any Help to fix that?
And thats the code generated for the servo.
(1,271 Views)
Re: Servos not working
Hi Paqiu,
I reproduced the program using OSX 10.9 and Windows 7 operating systems, and was able to run the teleop program without error.
Are you sure the brick has sufficient memory? Try deleting images and sounds, and any old programs from the brick using the NXT Terminal.
(349 Views)
thanks for the advise, ill try that as soon as i can
(349 Views)
Did this end up working for you?
(349 Views)
Definitely, we had so much memory been used, now it works perfectly fine, Thanks
(349 Views)
