FIRST Tech Challenge Discussions
Reply
Reset motor encoder block resets to zero through every iteration
I have a program with an infinite loop that prints the current motor position to the screen. However, when I run it, it resets to zero through every iteration.
Does anyone know why this is so?
Message 1 of 2 (1,121 Views)
Reply
Re: Reset motor encoder block resets to zero through every iteration
One of the problems I see is you have no constant set for the power associated with your motor, so it shouldn't move.  This may give you a value of zero and appear that it is resetting.
Message 2 of 2 (296 Views)
Reply
