FIRST Tech Challenge Discussions
A motor doesn't respond in FCS Teleop
I have a teleop program generated from the remote control editor. When I go to use it in the field control system, one of the motors turns on, doesn't stop, and doesn't respond to joystick input; but the other motor does. I tried running the teleop program with the remote control editor and the program works perfectly, so I don't think it is a problem with the teleop program.
I am using National Instruments 2012 LabView for Lego Mindstorms, LabVIEW Toolkit for MINDSTORMS Competition 2014 - 2015 (LTMC), Field Control System 3.0.6, and a Cisco Linksys E1200 router
(5,303 Views)
Try checking the switch on the back of your Logitech controller--it should be in the "D" position.
(4,494 Views)
Thanks, it works
(4,494 Views)
