FIRST Robotics Competition Discussions
Reply
Stop motor movement when it reaches a specific encoder value
Go to Solution
Highlighted
I'm supposed to be programing a motor that will start to turn when i push a button then when it reaches a encoder value it stops. Our team is using analog encoders if that makes a diffrence.
Message 1 of 2 (241 Views)
Reply
Accepted by topic author we516waeg651aweg165aweg
‎02-23-2017 01:44 PM
Re: Stop motor movement when it reaches a specific encoder value
What type of drive are you using? (Tank, Mechanum, Swerve)
Are analog encoders attached to all the wheels?
Are you using Talon SRX or another motor controller?
Do you have a Gyro sensor on your robot (It is easier to use for rotating to angle).
Message 2 of 2 (203 Views)
Reply
