FIRST Robotics Competition Discussions
Low-Level VIs appear disabled
Hello there,
I am in a dilemma. I successfully implemented the 2017 vision example code, but when I tried to edit it to recognize the new stripe set, certain VIs appear grayed-out or disabled. When I repeated all these steps exactly on a 32-bit computer running Windows 7, this did not happen, but I cannot get it to work on the computer I need it to work on, which runs Windows 10.
I need this code working on my Win10 computer ASAP. Any help would be much appreciated.
Thank you!
(2,681 Views)
I am running on an 64bit Laptop with Windows 10... can you post a copy of your project with directions on what VI is giving you problems? I will take a look on my system.
Are all the Vision related subVI's the ones giving you problems? It could be that your Vision module is not licensed or activated.
Ryan
(2,625 Views)
