There is some crucial information missing from this document, and the missing information is placed in an HTML file in your project folder. It's titled "Robot Simulation Readme.html"
Please add in all the information below into the PDF. It skips on all of the servos for the arm and camera are not even mentioned in the PDF.
Actuators on this simulated robot
Left Motor
Digital Module = Digital Module 1
PWM Channel = PWM 1
Right Motor
PWM Channel = PWM 2
Camera Servo
PWM Channel = PWM 5
Angular Range = 170
Arm Servo
PWM Channel = PWM 6
Angular Range = 170
Gripper Servo
PWM Channel = PWM 7
Angular Range = 170
Sensors on this simulated robot
Encoder on Right Motor
A Channel = DIO 3
B Channel = DIO 4
Encoder on Left Motor
A Channel = DIO 5
B Channel = DIO 6
Gyro
Analog Module = Analog Module 1
Analog Channel = AI 1
Ultrasonic
Ping Digital Module = Digital Module 1
Ping DIO Channel = DIO 1
Echo Digital Module = Digital Module 1
Echo DIO Channel = DIO 2
AXIS M1011 Camera
Thanks to Rachel Holladay from Team Combustion #1912 for this information!
Error -310194 occurred at NI_Robotics_Simulator.lvlibDESimulator_Motor.lvclass:Get Motor Index By ID.vi->NI_Robotics_Simulator.lvlib:Get Actuator By ID.vi->DC Motor Controller Simulator.lvclass:Initialize (Simulator).vi->WPI_MotorControlOpen&ConfigurePWM.vi->WPI_MotorControlOpen Talon.vi->Begin.vi->Robot Main.vi
