FIRST Robotics Competition Documents
[FRC 2015] Robot Framework Tutorial
by Member Kevin_F on ‎01-03-2013 08:11 PM
In this tutorial you will walk through the functionality contained in the framework supplied with LabVIEW FRC.
A programming framework is piece of default code that provides the overall structure, or architecture, of your program. It defines interaction between different code sections, and provides designated places
to insert specific functionality. The frameworks are supplied as a starting point; they let you focus on actual functionality in the limited time available to you, rather than program architecture.
FRC Robot Framework Tutorial
Contents:
  • Introduction
  • Creating an FRC Robot Project
  • The FRC Robot Project
  • Robot Main VI
  • Adding an Accelerometer to the Periodic Tasks VI
  • Using the Robot Global Data Variable
  • Conclusion
Comments
Member rdtech
Member
I don't know why you would have to set the center value and gain value of the accelerometer every iteration of the periodic task loop. These values are the same as when the accelerometer was initialized.
Member Ash5851
Member
Someone should make a 2016 LabVIEW FIRST robotics programming guide. It would be very useful with the new RoboRio compared to the previous documents concerning the cRio. Thanks.
Member BoKnows
Member
The 2015 version uses the roboRIO.  Was there something in there, specifically, that could have been explained better to help out?
Member Ash5851
Member
Yeah, so what does the bottom section of the code do? In the while loops
Member BoKnows
Member
Which page do you mean?  There's quite a few while loops in the document.
