Please note that the content contained in this document is out-of-date for the current competition season. Please feel free to use it as a reference moving forward.
This document contains the FRC 2012 known issues that were discovered during the 2012 season. Not every issue known to NI will appear on this list; it is intended to only show the severe and common issues.
Source Forge Tracker ID
| Known Issue
| Workaround
| cRIO Imaging Tool - Timeout error due to various network interface configurations | |
| artf1436 | Setup Axis Camera Tool - Axis 206 camera loses communication after power cycle | |
| Kinect does not work if Cypress IO has been set to Enhanced Configuration, but the board is not connected | - Choose Compatible for the configuration OR plug in the Cypress board
| Running the project has no issues, but building it fails explaining that it cannot save the Vision Processing VI in a bad state without a diagram. | - Modify the build settings/Additional Exclusion to uncheck the bottom checkbox that says Modify project library file after removing unused members
| If CAN is used in the Autonmous VI, the robot cannot transition to the Disable or Teleop VIs. | - Terminate the autonomous routine just before the VI would be aborted, to stop calling CAN updates before the end of the autonomous period
- Move the CAN updates to Periodic tasks and have autonomous simply update setpoints
