Please note that the content contained in this document is out-of-date for the current competition season. Please feel free to use it as a reference moving forward.
There is a green status LED at the bottom of the digital side car, directly to the right of the white plastic two pin connector. This LED is pictured in Figure 1. This LED can be used to monitor FRC system states.
When monitoring the robot status light (RSL) with the robot mounted BFL, make sure there is a jumper between Ya and Yb on the BFL. Without this jumper, the BFL will incorrectly flash different codes than the digital sidecar LED.
Figure 1
There are four states of this status LED, listed here in order of priority. If multiple occur, the highest one listed is what is displayed.
- Fast Blink (200ms on / 200ms off) - System error: No driver's station communication, bad cRIO Image, bad team ID, extensive communication errors.
- Steady on - Everything ok
- Fast-Slow Blink (200ms on / 900ms off) - Low battery (<12 Volts) and system disabled either by system watchdog, user watchdog, or Driver's Station set to disabled
- Slow Blink (900ms on / 900ms off) - System disabled
