In computing, a "Watchdog Timer" is a timing device that triggers a piece of hardware or software into a fail-safe state due to some fault condition. The general concept is that when a system is running with a watchdog on, the system must 'feed' the watchdog every X amount of time. If the system is stuck doing something else, or there is a fault that prevents the system from feeding the watchdog, when X amount of time passes the system reverts to a fail safe state.
In the FRC control kit, there are two watchdogs.
System Watchdog
The system watchdog (always enabled) ensures the wireless and Compact RIO system are behaving properly. This is a watchdog built into the Compact RIO FPGA that is fed TCP packets through the Ethernet connection (wired or wireless) from the driver station to the cRIO-FRC. This happens by default and requires no additional setup from the user beyond normal IP address setup of the cRIO and driver's station. If anything disrupts the connection between the drivers station and the cRIO (such as a loss of wireless network connection) the FPGA turns off all PWM and actuator outputs. This immediately stops the robot and prevents a run-away robot. Additionally, the system watchdog will trigger if the competition dongle is not attached to the drivers station in the enabled position. Teams do not have any way to access or modify this watchdog. Ideally, this watchdog is entirely transparent to the user and just works.
User Watchdog
The user watchdog is optional. The user watchdog is provided in the robotics palette as a option for teams that wish to implement their own watchdog into their code. This user watchdog would be on top of the system watchdog. The user watchdog is made up of a collection of VIs that can be found in the Functions Palette at WPI Robotics » Utilities » Watchdog. Users can look at the LabVIEW Help for the specifics about each of the VIs that make up the Watchdog palette. Additionally, there is a great user watchdog example that installs with LabVIEW which can be found by clicking More... at the bottom right of the Getting Started window. If the User Watchdog is triggered, either by not being fed in time or by manual triggering, it immediately turns off all motors and actuators just like the system watchdog. An example of using this might be checking an accelerometer to see if your robot has flipped over and killing the watchdog if it has.
When a watchdog has triggered
The easiest way to tell if a watchdog has triggered is by looking at the green LED at the bottom of the digital side car, directly to the right of the white plastic two pin connector. This LED is pictured in Figure 1. If this LED is blinking slowly,either a watchdog has triggered or the system is disbaled by the driver's station. Your system is in the fail safe state where no motors or actuators can be driven. If this LED is solid, the system is operating normally. More information about the status LED can be found in Digital Sidecar Status LED Meanings.
Figure 1
Debugging watchdog problems
