Example Code
Read Cognex DM200 barcodes
Products and Environment
    Hardware
  • Instrument Control
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to open a connection to a Cognex DM200 scanner, initiate a read request and wait for the read data string.
Description
This example shows a way to use a Cognex DM200 scanner with LabVIEW. It is very basic and use only the commands Trigger ON and Off.
This example uses the LabVIEW Internet Toolkit to communicate with the scanner over Telnet. The Internet Toolkit is deprecated as of LabVIEW 2012 and is no longer shipped. You must replace the Telnet VIs with pure TCP/IP VIs if you want to use this example with the latest version of LabVIEW.
LabVIEW Internet Toolkit Deprecated - National Instruments
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • LabVIEW Internet Toolkit 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • Cognex DM200 scanner
  1. Download and open the attached VI
  2. Run the program
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
Reibungszauber
Member
Member
on
please can you convert this to an older Version 8.6 or give a print/ picture of the block diagram?
Thanks a lot and best regards
George
Brooks.Nelson
Member
Member
on
Is there a way I could get the internet toolkit with the telnet, so I can load this vi?  I downloaded 2012 but the toolkit was not there.
