Demonstrates how to implement Ctrl-A support to select all text in a string control.
Description
Hardware and Software Requirements
LabVIEW 2015 (or compatible)
1. Run the VI. 2. Type text in the string. 3. While the string has focus, press Ctrl-A. You should see all the text in the string highlighted. 4. Click Stop to stop the VI.
FYI, there is a discussion on the DQMH forums here about how to use a simple DQMH module to add Ctrl-A support to an arbitrary number of strings in an arbitrary number of VIs simply with a single subVI.
