Overview
Builds a signal comprised of multiple tones that will be downloaded to an arbitrary waveform generator.
Description
This code was created to build a signal comprised of multiple tones that will be downloaded to an arbitrary waveform generator. The important part about the functionality of this VI is that it can take the size of the onboard memory as an input and calculates the minimum number of cycles of each of the waveforms that will fit in that onboard memory size. There is a subVI that makes these calculations that is also included in the zipped folder.
Requirement
Software:
Labview 2012 (or compatible)
Unzip the attached folder and add Multi-Tone Waveform Generation.vi to your VI's block diagram. Ensure that f1_f2_f3.vi is also included in your project or project folder.
Block Diagram
