Version 1.0 for LabVIEW 2010 (source and executable) and 2011 (executable).
This is an example that ships with the ECU Measurement and Calibration Toolkit 2.2+. It is simply built here as an executable for those without LabVIEW to use. For example, those who use the ECU Measurement and Calibration Toolkit with NI VeriStand.
Electronic control units (ECUs) use a locking mechanism to prevent accessing the ECUs by unauthorized persons.
This is working the following way:
ASAM Measurement and Calibration standard defines an interface to a DLL which implements a function to create a key from the seed. The DLL has to contain a function with a given name. CCP defines one function to obtain the key. If for the priviledges Calibration, DAQ and Programming different algorithms are used, the master has to use 3 different DLLs implementing the algorithms. XCP defines a function with a parameter describing the priviledge to unlock, so one function can implement different algorithms for the given priviledge.
This allows the ECUMC master to call the DLL which is placed on another computer. This can be usefull for example when the available DLL is compiled for Windows and cannot be executed on VxWorks or Pharlap RT system.
4 DLLs for remote access are included. These DLLs connect to the seedkey server, which then calls the real seedkey DLLs:
1. Change the seedkey DLL names in your .a2l file to reference these DLLs.
See below for examples in CCP and XCP A2L file:
/begin SEED_KEY
"rskCcpCal.dll" "rskCcpDaq.dll" "rskCcpPgm.dll"
/end SEED_KEY
SEED_AND_KEY_EXTERNAL_FUNCTION "rskXcp.dll"
2. Start the server on Windows and select your seedkey DLL for every access type you want use on the RT system.
3. Create an ecumc.ini file in which you configure the port number (which is selected in the server) and the server IP address (displayed by the server) and copy this file to the root directory of the RT system. (using FTP)
The following shows an example of the ecumc.ini file content:
[SeedkeyServer]
name="10.89.1.107"
port=17444
(Example ecumc.ini file is in the built directory)
4. Use your ECUMC application
