Overview
This code allows the user to remove unwanted string characters from a 2-D string array from file or from a test string control.
Description
This code was developed as an example to remove spaces from a 2-D array of strings. The strings themselves had spaces between each character which needed to be removed before they could be converted to a numeric. In the code, the strings are engineering strings, though they could easily be any string, simply replace the string to numeric converter to a different VI to suit your needs.
Requirements
VI Block Diagram
