Example Code
Programmatically deploy WSN Application image to multiple WSN Nodes in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI shows how to programmatically deploy WSN Application image to multiple WSN Nodes
Description
National Instruments wireless sensor network (WSN) measurement nodes offer low-power, reliable operation for long-term, distributed deployments. With the LabVIEW Wireless Sensor Network (WSN) Module Pioneer, you can use graphical programming to customize the node’s behavior, adding intelligence to extend battery life; increase analog and digital input performance; perform local control, analysis, and data reduction; and interface with custom sensors. You can download LabVIEW WSN applications wirelessly to NI WSN measurement nodes, allowing seamless updates to deployed nodes.
When working with a large Wireless Sensor Network, one can reduce deployment time by programmatically uploading a WSN application image to multiple WSN nodes using the powerful WSN Host API. In specific, the implementation of WSN Deploy Firmware.vi helps deploy a WSN application image to all programmable WSN nodes registered to a programmable WSN Gateway cutting down the deployment time of large WSN test beds.
*Multiple WSN image deployment can only work if all programmable WSN nodes are the same model.
Attached is a project containing a sample VI which uses the WSN Deploy Firmware.vi to update all registered programmable WSN nodes.
Requirements
Software
  • LabVIEW 2012 (or compatible)
  • LabVIEW Real-Time Module 2012 (or compatible)
  • LabVIEW Wireless Sensor Network Module (or compatible)
  • NI-WSN 1.3.0 (or compatible)
Hardware
  • Programmable WSN Gateway (NI 9792)
  • Programmable WSN Nodes (NI WSN-3202) x3
  1. Register all programmable WSN nodes on your WSN Gateway using Measurement & Automation Explorer.
  2. In the Project Explorer of LabVIEW, build the application on the first WSN node which will generate a <Your Application Name>.pkg file in your project directory .../<Your Project Name Folder>/<WSN Gateway>/<Node>/<WSN Application Name>/<Your Application Name>.pkg
  3. Upload via FTP the *.pkg file to the programmable WSN Gateway.
  4. Open, configure, and run WSN9792Main.vi. Make sure to specify the correct location of the *.pkg file in relation to the programmable WSN Gateway.
  5. The VI will scan for all registered programmable WSN nodes on the gateway and it will upload the *.pkg firmware image to all. The VI will stop execution until the very last programmable WSN node has been uploaded with the firmware.
VI Block Diagram
SnapCrab_WSN9792 Main 2012 NIVerifiedvi Block Diagram_2017-10-16_0-15-43_No-00.png
WSN node on Measurement & Automation Explorer
Aldo A
