Overview
This small code example demonstrates techniques to convert from DAQmx Physical Channels to a ListBox and back again
Description
This is useful if you want to show the physical channels to the user in listbox format.
Requirements
VI Block Diagram
First, thank you for posting the example. Could you please explain how to demo this example? Below is my sequence
*Click on Run
*Click on physical channels in
*Click on browse
*Select item(s) is empty, how do I populate (customise) this?
I notice you have used a Type Cast to do the conversion.
The list of phycisal channels will be the same as those within Measurement and Automation Explorer.
If you don't have any hardware present, this example will still work by manually typing physical channel names into the 'physical channels in'.
Chris
