Overview
Reads a Karnaugh Map and returns an array of 1s and don't cares.
Description
Select the value of the Karnaugh Maps. This uses an enum with three options: 0, 1 or x.
Careful ordering of the elements in the cluster (right click - reorder controls in cluster) means that when we convert to an array, we can very easily find where the ones and don't cares are using conditional array outputs.
The output arrays are set to display in binary format with 4 minimum chars (pad with zeros on the left)
Requirements
VI Block Diagram
