Example Program Drafts
IMAQ RGB Hue and Color Manipulation
by Member Joel Khan on ‎12-13-2010 11:35 AM - edited on ‎12-20-2016 11:08 AM by Member Example_Scrubber_Christoph
Overview
The example demonstrates how to extract color planes from an image and how to manipulate them.
Description
This example extracts the red, green and blue hue planes from a 32 bit RGB image. Once extracted, these hue planes are multiplied by user controlled values and recombined to create a new 32 bit RGB image.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Open the attached file
  2. Run the VI
  3. Change the multiplier settings and check how the extracted hue planes and the resulting image change
  4. (Optional) Click Reset to set the multipliers for all color planes to 1
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
Member FilipeV
Member
Excelent tutorial. Where do I get that "IMAQ ExtractColorPlanes? I can't find it anywhere LabVIEW. I use the 2011 version and have Vision installed. Thanks in advance.
Contributors
