Overview
Get information on COM port by Slot and port in Chassis So you can know which physical output/input you use even if cards was swaped.
Description
VI pull Card information (Resource Name and Slot) using nisyscfg VI's and then it load niserial.dbs in ni-rt\system where you can find Visa Alias and Port by resource name.
Good solution for customer maintenance on-site of PXI system by switching malfunction cards without configuring COM port alias manually in NI-MAX.
The manual process is OK for experienced Technician but the on-site operator would have a problem to set new card COM alias, especially in viable systems.
Was tested only on system with PharLab OS
Requirements
Software
NI LabVIEW 2015
NI Real-Time
Hardware
Real-Time Target (Was tested only on PXI Real-Time Controller)
Realveant Links
Enumeration and Naming of NI-Serial Ports and Other PCI Devices
http://digital.ni.com/public.nsf/allkb/6511208D0D82A8C586256D18005F1545
Problem dwscription
Or Hirshfeld
Application Enginner
SK-Electronika
Israel
SK Electonika Website - http://www.sk-advanced.com/category/electronics-1
Linnked-In Profile: https://www.linkedin.com/in/orhirshfeld
I have a PXI system with 2 Serial cards. Each of the serial cards has 4 ports. The VISA resource name gets changed everytime i change the hardware slots. Is it possible to configure the port name programatically?
I use windows 7 64 bit OS.
Would appreciate any help.
Sreekanth
I pulled data from 2 different files and than updated one of them
i needed to know on which slot a card is connected and which COM ports are assinged to him
than i can rename the com ports according to what i need
it built for NI-RT PXI with Pharlab OS but as far as i know Pharlab is a stripped down Win OS so maybe it's similar
I know that in device manager you can manually change the com number so maybe there is way to change it progmatically by modifying Registry or linking to some windows function
i would also try to set the com name using NI-MAX
