Example Code
Capturing Events from VIs in SubPanels
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This project demonstrates capturing events from front panel objects of a subVI that is running in a subpanel.
Description
The main VI uses VI Server to get a reference to the front panel objects, and then can dynamically register a value change event for a front panel object of the dynamically called Sub VI
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run VI
VI Block Diagram
Comments
jjsanchez83
Member
Member
on
Can you attach for Labview 2009^? thanks
Chris.N
Member
Member
on
I just attached a version that was saved in 2009.  I didn't take the time to test in 2009, I just saved for previous version.  Let me know if it works, otherwise I would rebuild the VI from looking at the concept in the images.
Cheers!
jjsanchez83
Member
Member
on
Hi Chris,
thanks for your reply. It doesn´t work in 2009 because the object "start asynchronously call" does not exists but I will take you scheme and I will try to solve using "invoke mode" run to call the VI.
