Example Program Drafts
Automatically adjust table width
by Member BROhan on ‎02-16-2011 04:22 PM
Introduction
This VI allows the user to input text. Normally, you would need to manually adjust the cell widths. However, with this VI, the cell widths are automatically adjusted based on the text rectangle and "fudge" factor.
Comments
Member GriffinRU
Member
I haven't had a chance to load vi itself, do not have 2010 at home yet.
But, it would work better if you calculate text rectangle also based on font type, size and style. And adjust cell width after entire row filled to maximum width, in case cell's data is wider than header.
