Example Program Drafts
Array(Table) Background Colors based on Thresholds.
by Member Jamie_J on ‎11-05-2012 04:22 AM - edited on ‎01-13-2017 04:37 AM by Member Jessica.xu
Overview:
This VI generates a random set of data and formats into an array. This array is then passed into a table where the background color of the cells is modified dependent on the individual cell's data value
Requirements: LabVIEW 2012( (or compatible)
Instructions:
1. Run the vi.
2.Modify the higher limie and lower limit to change the background color
Comments
Member Fred_A
Member
Thank you for this nice VI. Can you add an other VI with an older version of LV please ?
Member Jamie_J
Member
Thank you for the comment Fred. Added version for LabVIEW 8.6.
Jamie
Member SwapsG
Member
Thank you for this vi. helpful for me.
$waps.
Member Zbigniew_StS Member
Member
The good point is to use property node : Defer Panel Updates before and after operating at table property.
Member yueno
Member
It may use the following KB to initialise the GB color.   http://digital.ni.com/public.nsf/allkb/B8700C12AC7CE927862569DD0063CB0A?OpenDocument
Contributors
