NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
skyfe
PCI-7831 tutorial for beginner
I am new to FPGA programming in LabView. I know that I can't use my PCI-7831R with the DAQ- assistant, I read it in a different thread.
Just to know how to use it in my program I would need to know the following:
Continuous read an analog signal with my PCI-7831R and display it in a waveform and anumeric field as voltage.
Is there any tutorial beginning from "ZERO" (which means open a blank vi) on how to creeate such a VI?
Thanks you.
Member
Vineet A.
Re: PCI-7831 tutorial for beginner
There are a number of options for getting started with your PCI-7831R.
Here's a link to a webcast that you might find helpful, which shows how you can start from scratch and build a continuous analog input application.
http://zone.ni.com/wv/app/doc/p/id/wv-70   (Coincidentally, the demo also uses a PCI-7831R.)
Here's a link to a tutorial that shows how to build the host VI from scratch, and add scaling to convert from I16 values to voltages.
http://zone.ni.com/devzone/cda/tut/p/id/5906
You could also start with the LabVIEW FPGA Wizard, which can be used to generate code for continuous analog input.
Hope this helps.
Vineet A.
Member
kurb
Whats the range of the I16 values to correspond with the -10 to 10 volts range?
Knight of NI
RavensFan
I16 ranges from -32768 to +32767
If that doesn't answer your question, then please be more specific.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
