08-25-2013 08:18 AM
his is my main question also: I do not know what dsa12 contain. if I know the block diagram, i would know hot to rebuild it, but i do not know what it contain, it looks just like a block, a subVI, but i can't open it , because it was created in a version earlier than labview3.
Do you have any other ideeas?
Georgiana
08-26-2013 10:21 AM
From the description in the word document, and from the pictures of the front panel, the DSA12 VI calculates a series of common Sound and Vibration measurements. These are available in the NI Sound and Vibration Toolkit, or in more basic form in the LabVIEW advanced analysis library.
I would make a list of the functions from your word document, then look in LabVIEW signal processing library for similar functions. Start with one function, and send your signals into it. Iterate until you are satisfied with the results. Then go to the next function.
If you can afford, the sound and vibration measurement suite, or the toolkit, this will save you a good bit of time.
Hope this helps.
Preston
