Dynamic Signal Acquisition
Reply
simulated shaft centerline plot
I try to simulate data for using the "Shaft Centerline ExpressVI" (NI Sound and Vibration). But my "Shaft Centerline Plot ExpressVI (sim).vi" doesn't work and I don't know why Smiley Sad
The ExpressVI shows no plot and the error massage "The input signal is empty." appears.
Has one of you an idea?
Jens
Message 1 of 6 (3,368 Views)
Reply
Re: simulated shaft centerline plot
Speed profile is not likely sampled at the proper interval (at tachometer pulse positions). Please post back if you can verify sampling or need help converting speed profile to speed position info.
The speed waveform is also missing required attributes. Please refer to the generated code for the Tachometer Processing Express VI for how to attach all required attributes. (specifically OAT Convert Speed XY Graph to Waveform.vi)
Are you trying to simulate signals because the analog tachometer signal is not available and saved, or because you are trying to input simulated data into the Shaft Centerline Express VI?
Doug
Message 2 of 6 (3,364 Views)
Reply
have you tried the example:
LabVIEW\examples\order analysis\shaft centerline plot
In your eample, your speed profile should have at least one speed instance per revolution, not sure if this makes a difference.
Preston Johnson
Principal, Subject Matter Expert Condition Monitoring Systems
Allied Reliability Group
512 431 2371
johnsonp@alliedreliability.com
Message 3 of 6 (3,363 Views)
Reply
What do you mean with "at the proper interval"? And how can I change it?
The data I'm using is generated by the S&V-example "oax_Load Shaft Centerline Data.vi".
Yes, I need help in converting the speed profile.
Do you mean the following attributes?
missing attributes?
I need the possibility to simulated shaft centerline plots on my desk. But not like the Example "Shaft Centerline Plot (Simulated).vi from the S&V-libary. I want to generate data by myself, with different speeds and offsets (shaft centerline motions), so that I can proof that the algorithm works correctly.
Message 4 of 6 (3,354 Views)
Reply
Yes I tried the example. But I want to program a shaft centerline plot with my own data. On this way I want to proof that the algorithm works correctly.
Message 5 of 6 (3,352 Views)
Reply
Highlighted
... that is what I need Smiley Happy
Message 6 of 6 (3,350 Views)
Reply
