11-28-2011 06:01 AM
I try to simulate data for using the "Shaft Centerline ExpressVI" (NI Sound and Vibration). But my "Shaft Centerline Plot ExpressVI (sim).vi" doesn't work and I don't know why 😞
The ExpressVI shows no plot and the error massage "The input signal is empty." appears.
Has one of you an idea?
Jens
11-28-2011 09:55 AM
Speed profile is not likely sampled at the proper interval (at tachometer pulse positions). Please post back if you can verify sampling or need help converting speed profile to speed position info.
The speed waveform is also missing required attributes. Please refer to the generated code for the Tachometer Processing Express VI for how to attach all required attributes. (specifically OAT Convert Speed XY Graph to Waveform.vi)
Are you trying to simulate signals because the analog tachometer signal is not available and saved, or because you are trying to input simulated data into the Shaft Centerline Express VI?
11-28-2011 10:04 AM
have you tried the example:
LabVIEW\examples\order analysis\shaft centerline plot
In your eample, your speed profile should have at least one speed instance per revolution, not sure if this makes a difference.
11-29-2011 06:22 AM
What do you mean with "at the proper interval"? And how can I change it?
The data I'm using is generated by the S&V-example "oax_Load Shaft Centerline Data.vi".
Yes, I need help in converting the speed profile.
Do you mean the following attributes?
I need the possibility to simulated shaft centerline plots on my desk. But not like the Example "Shaft Centerline Plot (Simulated).vi from the S&V-libary. I want to generate data by myself, with different speeds and offsets (shaft centerline motions), so that I can proof that the algorithm works correctly.
11-29-2011 06:39 AM
Yes I tried the example. But I want to program a shaft centerline plot with my own data. On this way I want to proof that the algorithm works correctly.
11-29-2011 06:43 AM
... that is what I need
