02-11-2010 05:05 PM
Hi ColeR,
I am working with akodu on the virtual lock-in NI-SCOPE VI. Yes we are using the 2D DBL instance of the NI-SCOPE Fetch VI. We are wiring the the wfm output directly to the PLL; it had been going through a transpose function and then directly into the PLL but wiring it directly did not help the problem.
As for the NI-SCOPE acquisition, the output signal from the PLL appears to be correct. Because of this we don't think there are any acquisition or triggering issues. You can take a look at our VI to see if we are using the reference trigger correctly with NI-SCOPE or if the reference trigger needs to be connected in some way to the lock-in VI's.
As another diagnostic clue that may help, the shape of the direct signal that is displayed on the output along with the lock-in output changes quite drastically when both the sampling rate and min record length are adjusted (within reasonable values for each of course).
Our main question is whether the issues we are seeing are stem from how we are feeding the signal into the lock-in VI's (in terms of rate or other properties of the signal)? What are the requirements of input signals for the lock-in VI's so that they produce output comparable to the input in terms of resolution, etc..?
Thank you very much for your help.
Sincerely,
dvdj
05-31-2014 10:55 AM
Hi
I want to download the NI Lock-In amplifier toolkit for Traditional Daq but I cant find it,
I am a newie.
Ali
04-19-2016 08:07 AM
Hi everyone,
I am currently trying to make a lockin amplifier using a NI PXI-4461 card.
The configuration is quite simple :
- the frequency reference is on the analog input AI0
- the signal is plugged on the anlog input AI1
The output information that I want are :
- Frequency
- R
- Y
- Theta
Do you have any idea ?
Regards.
04-20-2016 10:53 AM
Hi Mars!
Unfortunately, I do not believe that NI ever released a fully supported toolkit to create a lock-in amplifier. Any code that is available for this purpose was written primarily by users as free software. You can find some of this in other links in the forum, such as here.
Additionally, I would highly recommend you make a new forum topic instead of posting in a post that is over 6 years old.
