To whosoever it may concern,
i am using two microphones (actually to calibrate one with the other).
the problem is ...one of them is battery powered while the other needs a B&K type 2839 power supply( which i've connected to the same plug as the DaQ connector box).
which of these can i consider as a grounded signal/floating signal.
i heard somewhere that most instrumentation microphones are floating signal sources.is it applicable in this case?
waiting for reply.
thanks in advance
