Dynamic Signal Acquisition
amplitude and level
Dear sir
What is the difference between amplitude & level measurement with vibration level measurement? I found both has measurement such as RMS and Peak value, but it gave a quite different value when I try it simultaneously.
Can I used the amplitude & level measurement to measure vibration level?
(5,854 Views)
Product differences:
Amplitude and Levels Step is activated by SignalExpress
Vibration Level Step is activated by Sound and Vibration
Functional differences:
Amplitude and Levels Step gives a new result for every block (Step will hold peaks if you check that option)
Amplitude and Levels Step supports measurement of DC
Vibration Level Step always returns the result from the last reset
Vibration Level Step does not measure nor remove DC component; instead this step assumes vibration around equilibrium and/or that the data was acquired with AC coupling
Vibration Level Step supports time-domain integration (to convert acceleration --> velocity --> displacement) prior to the level computation.
Vibration Level Step supports industry-standard (fast, slow, impulse) and custom time constants for exponential level measurements.
What types of vibration are you trying to measure?
Vibration during shock event --> Amplitude and Levels
RMS level of an arbitrary signal --> Amplitude and Levels
Machine or structural vibration --> Vibration Level
In many cases, both steps can be used simultaneously Amplitude and Levels Step outputs can be used for trigger conditions. Vibration Level output (such as Exponential Level and Max-Min) can be used for logging and tracking of industry-standard levels.
Doug
NI Sound and Vibration
(5,845 Views)
