The minimum frequency you can set for the Swept Sine in DSA mode is 0.1 Hz. This is limited by the finite size of the output buffer and the minimum update rate for the DAC. The DAC must maintain a minimum rate of 1.25kS/s for accurate results. Please see the NI-4551 User Manual for more details.
Brent R. Applications Engineer National Instruments
