09-18-2008 04:40 AM
Thanks a lot if you can help me.
Mathieu
09-18-2008 01:31 PM
Hi Mathieu,
I found this knowledge base article: 43J65CAY which is about compensating for ADC group delay in sigma delta converters like the ones on the 9233.
http://digital.ni.com/public.nsf/allkb/CAE12AA9BCAA51A48625722C004866F8
So if they are all sharing a sample clock, but the 9233 appears to be lagging behind, it sounds to me like you are right. It has to do with the architecture of the ADC on the 9233 (similar to what would be found on other 24-bit audio type devices). Putting in a delay like the knowledge base article describes ought to improve synchronization.
As to the analog output, I have some questions for you. Do you need to hardware synchronize your analog signal generation to the turntable or would software sequencing be sufficient? I'm imagining that you have a table that you set to a particular position, run a test, and then turn the table to a new position, and run another test, and so on. Is that the case? If so, you may not need to synchronize the two outputs. You could just make sure that your sequence in software allows for sufficient delay between when you turn the table and when you run a test.
Although there is more than one way to do it, you could definitely use a sequence structure (flat or stacked) to ensure the order of each task.
Hope that helps.
09-19-2008 03:40 AM
Hi Dousley,
thanks a lot for your answer. I'm going to study your article concerning delay compensation.
Concerning the measurements with the turntable, you are right: the table is at 0°, a measurement is done, then it turns to 15°, a 2nd measurement is done, ....
I 'll try a sequence structure. In fact, I had imagined a much more complicated system 🙂
Thanks for your advices.
Mathieu
