08-12-2009 09:21 PM - last edited on 02-29-2024 03:52 PM by migration-bot
I have a PCI 6534 & PCI 6602, will a SH6868 connector work for either one? What is the difference between the SH6868 vs. SH68-68-D1 as I couldn't find it on the two websites?
https://www.ni.com/en-us/support/model.sh68f-68f-cable.html
https://www.ni.com/en/search.html?pg=1&ps=10&q=182419-01
Thank you,
Russell
Solved! Go to Solution.
08-13-2009 04:17 PM - last edited on 02-29-2024 03:52 PM by migration-bot
Hi Russell,
Thanks for posting and welcome to the NI Forums!
The SH68-68-D1 is currently listed on both the 6534 and the 6602 product pages at the recommended cable. There are two primary differences between the SH68-68-D1 and SH6868:
Having said this, both cables do pass signals straight-through (i.e. pin 1 will go to pin 1 on the other end). The SH6868 should therefore be technically useable with the two devices but would likely be more susceptible to noise and crosstalk. If you try it out and have any problems with signal integrity I would suggest looking into obtaining the recommended cable.
-John
08-13-2009 04:33 PM
Hi John,
Thank you for your quick and thorough response. It has been very helpful.
Russell
