Hi again,
Thanks for your reply. I´ve already read something about NI recommended cables, but i don´t sure about what kind of cable I need. When I read something like this:
R68-68
" A low-cost, 68-conductor flat ribbon cable terminated with
two 68-pin connectors. Use this cable to connect a 68-pin E Series,
S Series (except NI 6143), or B Series multifunction DAQ device to
68-pin accessories." (For example)
What are 68-pin accesories? Ok, more or less i know what kind of 68-pin accesories, i think that a SH68-68-D4 connected between 2 PXIe-6545 can help me to debug some Generation/Acquistion apps, but, what about RIO devices? is it necessary a block connector? I have two 7853R, and all i need is (while HW is being developed) read/write from/to each of the 3 device connector (Device 1 - Connector 0 with Device 2 - Connector 0,...).
Thanks again
