09-24-2012 07:10 AM
I NEED TO SET UP SIGNS OF PROXIMITY SENSORS 7.8 mV / μ USING A NI-9221 WITH SOUND AND VIBRATION MEASUREMENT SUITE 7.0. NEED TO SEE THE VALUES OF GAP (LEVELS STATIC-DCVOLTS) AND ALSO THE VALUES OF RELACTIVE VIBRATIONS ON (DYNAMIC LEVELS μ-PK-PK).
TANKS.
OMR
09-26-2012 11:17 AM - last edited on 02-29-2024 03:46 PM by migration-bot
What hardware platform are you on? cRIO, cDAQ?
You may not have the choice, but the 9232 might be a better choice for prox probes (24bit, iepe, simultaneous sampling, etc.)
-Alan
09-26-2012 12:57 PM
Dear Alan.
Thanks for the help and suggestion.
Today I don't have other choice.
I'm working with cDAQ and I would appreciate if you could help me at this case, using the 9221.
Thanks.
09-26-2012 01:48 PM - last edited on 02-29-2024 03:46 PM by migration-bot
I'd start with a DAQmx tutorial:
This one is might be helpful:
Sound & Vib 7.0 was released a few years ago...so I'm not 100% certain, by there may be an example or two that use prox probes here:
<LabVIEW Directory>/examples/Order Analysis
