06-07-2017 12:04 AM
I'm using USB 6009 with the DAQ assistant to acquire my data. I use 2 channels on the USB 6009, Channel 1 is a square wave that goes from -5 to +5 V (2.3 Hz, 5k sampling rate; 1000 samples); Channel 2 is a bio-potential that is being recorded (5k; 1000 samples).
My channel 2 data is dependent on the transition of the square wave from -5 to +5 or vice versa. (i.e - every time a sign change occurs in my square pulse - a change occurs in my bio potential)
My goal is to detect this sign change and its corresponding change in the bio-potential (Ch2), ultimately leading to a matrix of "chopped windows" of bio-potentials (i.e - each sign change in channel 1 = 1 column of bio-potential in matrix built).
Approach:
I managed to identify the indices of sign change form positive to negative and vice versa and put it in a queue. I want to access the bio-potential at the indices obtained above, in order to chop a 1000 point window of bio-potential - i.e biopotential(index -250:index+750); and ultimately populate a matrix.
But am unable to do that.
Issues:
1. How do I consume channel 2 queue while consuming channel 1
2. Consumed data in queue did not seem to match the input order.
3. I think the way I am synchronously running multiple loops is incorrect - As I don't see what I am expecting to see.
4. How do I keep track of channel 2 index while consuming it from a queue?
5. Is there a better approach for all of this? - Am I missing something?
- Labview Version 2012; DAQ is replaced by Simulate signal for testing purposes.
Attached is my VI. Help is much needed and appreciated!
Thanks!
06-07-2017 04:59 PM
What exactly are you having issues with? It looks like you are de-queuing from each respective queue in the loops. Can you clarify what functionality you hope to achieve?
Queues work as a FIFO buffer; meaning that the first element you enqueue will be the first element de-queue. Is this not the order you are seeing?
What are you expecting to see?
I am not sure what you mean by the channel 2 index. However, the iteration index of the loop can tell you how many times the loop has run; Effectively telling you how many elements have been de-queued
Once we have a better picture of what you are trying to do, we may be able to help you set up a better architecture
